# Page Not Found
The URL `components/3_loads/apply_abolute_load_values` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Apply Absolute Load Values](https://docs.ladybug.tools/hb-energy-primer/components/3_loads/apply_absolute_load_values.md)
- [Apply Load Values](https://docs.ladybug.tools/hb-energy-primer/components/3_loads/apply_load_values.md)
- [Apply Setpoint Values](https://docs.ladybug.tools/hb-energy-primer/components/3_loads/apply_setpoint_values.md)
- [Apply ProgramType](https://docs.ladybug.tools/hb-energy-primer/components/3_loads/apply_programtype.md)
- [Apply Daylight Control](https://docs.ladybug.tools/hb-energy-primer/components/3_loads/apply_daylight_control.md)
GET https://docs.ladybug.tools/hb-energy-primer/components/3_loads/apply_absolute_load_values.md?ask=<question>&goal=<end_goal>
Full index: https://docs.ladybug.tools/hb-energy-primer/sitemap.md
Full export: https://docs.ladybug.tools/hb-energy-primer/llms-full.txt
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/hb-energy-primer/components/3_loads/apply_absolute_load_values.md`).
