> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-energy-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-energy-primer/components/3_loads/deconstruct_programtype.md).
# Deconstruct ProgramType
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-b14b73048af4305190ea928fe179d5d0fecbadd7%2FDeconstruct_ProgramType.png?alt=media)
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-c8654ce00df5e7000ea6d69308c756089566ba72%2FDeconstruct_ProgramType.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-energy/blob/master/honeybee_grasshopper_energy/src//HB%20Deconstruct%20ProgramType.py)
Deconstruct a ProgramType object into its component load objects.
* **program \[Required]**
  A ProgramType object or text for the identifier of a ProgramType to be looked up in the program type library.&#x20;
* **people**
  A People object that describes the occupancy of the program. If None, no people are assumed to occupy the program.&#x20;
* **lighting**
  A Lighting object that describes the lighting usage of the program. If None, no lights are assumed to be installed.&#x20;
* **electric\_equip**
  An ElectricEquipment object to describe the usage of electric equipment within the program. If None, no electric equipment is assumed to be installed.&#x20;
* **gas\_equip**
  A GasEquipment object to describe the usage of gas equipment within the program. If None, no gas equipment is assumed to be installed.&#x20;
* **hot\_water**
  A ServiceHotWater object to describe the usage of hot water within the program. If None, no hot water is be assumed for the program.&#x20;
* **infiltration**
  An Infiltration object to describe the outdoor air leakage of the program. If None, no infiltration is be assumed for the program.&#x20;
* **ventilation**
  A Ventilation object to describe the minimum outdoor air requirement of the program. If None, no ventilation requirement is be assumed for the program.&#x20;
* **setpoint**
  A Setpoint object to describe the temperature and humidity setpoints of the program.  If None, the ProgramType cannot be assigned to a Room that is conditioned.&#x20;
