Deconstruct Infiltration
Deconstruct an Infiltration object into its constituient properties.
  • infil [Required]
    An Infiltration object to be deconstructed.
    Text string for the infiltration display name.
  • flow_per_ext_area
    A numerical value for the intensity of infiltration in m3/s per square meter of exterior surface area. Typical values for this property are as follows (note all values are at typical building pressures of ~4 Pa):
    • 0.0001 (m3/s per m2 facade) - Tight building
    • 0.0003 (m3/s per m2 facade) - Average building
    • 0.0006 (m3/s per m2 facade) - Leaky building
  • schedule
    A fractional schedule for the infiltration over the course of the year. The fractional values will get multiplied by the flow_per_exterior_area to yield a complete infiltration profile.
