Read Room Comfort Result
Parse all of the common Room-level comfort-related results from an SQL result file that has been generated from an energy simulation.
  • sql [Required]
  • oper_temp
DataCollections for the mean operative temperature of each room (C).
  • air_temp
DataCollections for the mean air temperature of each room (C).
  • rad_temp
DataCollections for the mean radiant temperature of each room (C).
  • rel_humidity
DataCollections for the relative humidity of each room (%).
  • unmet_heat
DataCollections for time that the heating setpoint is not met in each room (hours).
  • unmet_cool
DataCollections for time that the cooling setpoint is not met in each room (hours).
