> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-energy-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-energy-primer/components/3_loads/deconstruct_setpoint.md).
# Deconstruct Setpoint
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-3e7e5594978343e6335833e8ae11315d6bf7e2ea%2FDeconstruct_Setpoint.png?alt=media)
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-b123f42be61b1b1c1891a24e2ed28a63e1c44623%2FDeconstruct_Setpoint.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-energy/blob/master/honeybee_grasshopper_energy/src//HB%20Deconstruct%20Setpoint.py)
Deconstruct a Setpoint object into its constituient properties.
* **setpoint \[Required]**
  A Setpoint object to be deconstructed.&#x20;
* **name**
  Text string for the setpoint display name.&#x20;
* **heating\_sch**
  A temperature schedule for the heating setpoint. The type limit of this schedule should be temperature and the values should be the temperature setpoint in degrees Celcius.&#x20;
* **cooling\_sch**
  A temperature schedule for the cooling setpoint. The type limit of this schedule should be temperature and the values should be the temperature setpoint in degrees Celcius.&#x20;
* **humid\_setpt**
  A numerical value between 0 and 100 for the relative humidity humidifying setpoint \[%]. This value will be constant throughout the year. If None, no humidification will occur.&#x20;
* **dehumid\_setpt**
  A numerical value between 0 and 100 for the relative humidity dehumidifying setpoint \[%]. This value will be constant throughout the year. If None, no dehumidification will occur beyond that which is needed to create air at the cooling supply temperature.&#x20;
