Visualize Thermal Map
Spatially visualize the detailed results of a thermal mapping analysis from a comfort matrix.
  • comf_mtx [Required]
    A comfort Matrix object from the "HB Read Thermal Matrix" component.
  • mesh [Required]
    Mesh objects that correspond with the sensor grids of the thermal map analysis. These will be , with a number of faces or vertices that match the number of input values and will be colored with results.
  • sim_step
    An optional integer (greater than or equal to 0) to select a specific time step of the comfort results to be displayed. Note that this will override any connected period.
  • period
    A Ladybug analysis period to be applied to select a slice of time across the comfort results to be displayed.
  • legend_par
    An optional LegendParameter object to change the display of the results.
  • mesh
    The input mesh objects colored with results.
  • legend
    Geometry representing the legend for the results.
  • title
    A text object for the title.
  • colors
    The colors associated with each input value.
  • values
    A list of numbers for each face of the mesh, which are used to generate the colors.
