> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-energy-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-energy-primer/components/6_result/read_generation_result.md).
# Read Generation Result
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-01997d20420aece9ddb7940fc33bf7b234746ea8%2FRead_Generation_Result.png?alt=media)
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-715e6912721851f1dc410714ec43afe136662595%2FRead_Generation_Result.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-energy/blob/master/honeybee_grasshopper_energy/src//HB%20Read%20Generation%20Result.py)
Parse electricity generation results from an energy simulation SQL result file.
* **sql \[Required]**
* **site\_totals**
Two numbers indicating the following energy values in kWh.
* Total on-site produced electricity (postive number)
* Total on-site electricity consumption (negative number)
* **utility\_totals**
Three numbers indicating the following energy values in kWh.
* Total on-site produced electricity consumed on-site (positive number)
* Total on-site produced surplus electricity sold to the utility (positive number)
* Total electricity purchased from the utility (negative number)
* **production**
A data collection of all on-site produced electricity (kWh). This represents the alternating current (AC) electricity coming out of the inverter that processes all on-site power production.
* **consumption**
A data collection of all on-site consumed electricity (kWh). This represents the electrcicity consumed by all heating, cooling, lighting equipment, fans, pumps, process loads, and water heaters. All of this consumed electricity is assumed to be alternating current (AC).
* **dc\_power**
A list of data collections for the direct current (DC) electricity produced by each on-site electricity generator (kWh). Each photovoltaic object will have a separate data collection.
