Detailed HVAC
Apply a detailed Ironbug HVAC to Honeybee Rooms or a Honeybee Model.
  • hb_objs [Required]
Honeybee Rooms to which the input Ironbug HVAC will be assigned. This can also be a Honeybee Model for which the relevant Rooms referenced in the _hvac_system will be assigned the HVAC system.
  • hvac_system [Required]
A fully-detailed Irongbug HVAC system to be assigned to the input rooms (or model).
Text to set the name for the HVAC system and to be incorporated into unique HVAC identifier. If the name is not provided, a random name will be assigned.
  • hb_objs
The input Rooms or Model with the detailed HVAC system applied.
