> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-energy-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-energy-primer/components/5_simulate/simulation_control.md). Agents can also search and read this documentation through its [MCP server](https://docs.ladybug.tools/hb-energy-primer/~gitbook/mcp).
# Simulation Control
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-362bf849feb66c0a873d2cbea01cbe06101f1981%2FSimulation_Control.png?alt=media)
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-bf65657524478a5f8b8e05440d7ebe6ffee033b2%2FSimulation_Control.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-energy/blob/master/honeybee_grasshopper_energy/src//HB%20Simulation%20Control.py)
Create simulation controls with instructions for which types of EnergyPlus calculations to run.
* **do\_zone\_sizing**
  Boolean for whether the zone sizing calculation should be run. Default: True.&#x20;
* **do\_system\_sizing**
  Boolean for whether the system sizing calculation should be run. Default: True.&#x20;
* **do\_plant\_sizing**
  Boolean for whether the plant sizing calculation should be run. Default: True.&#x20;
* **for\_sizing\_period**
  Boolean for whether the simulation should be run for the sizing periods. Default: False.&#x20;
* **for\_run\_period**
  Boolean for whether the simulation should be run for the run periods. Default: True.&#x20;
* **sim\_control**
  A SimulationControl object that can be connected to the "HB Simulation Parameter" component in order to specify which types of EnergyPlus calculations to run.&#x20;
