Read Custom Result
Parse any time series data from an energy simulation SQL result file.
  • sql [Required]
  • output_names [Required]
    A list of EnergyPlus output names as strings (eg. 'Surface Window System Solar Transmittance'. These data corresponding to these outputs will be returned from this component.
  • results
    DataCollections for the output_names.
