> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-energy-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-energy-primer/components/2_schedules/apply_shade_schedule.md). Agents can also search and read this documentation through its [MCP server](https://docs.ladybug.tools/hb-energy-primer/~gitbook/mcp).
# Apply Shade Schedule
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-f35b1f2cad893295a76e0a1af944642dd2584562%2FApply_Shade_Schedule.png?alt=media)
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-eee3557bad6f129afb66caeaa6103ea988d7f798%2FApply_Shade_Schedule.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-energy/blob/master/honeybee_grasshopper_energy/src//HB%20Apply%20Shade%20Schedule.py)
Apply a transmittance schedule to Honeybee Shade objects. Alternatively, it can assign a transmittance schedule to all of the child shades of an Aperture, Door, Face, or a Room.
This component supports the assigning of different schedules based on cardinal orientation, provided that a list of transmittance schedule are input to the \_trans\_sch.
* **hb\_objs \[Required]**
Honeybee Shades, Apertures, Door, Faces, Rooms or a Model to which the input \_trans\_sch should be assigned. For the case of a Honeybee Aperture, Door, Face, Room, or Model, the ShadeConstruction will be assigned to only the child shades directly assigned to that object. So passing in a Room will not change the schedule of shades assigned to Apertures of the Room's Faces. If changing these sub-children is the desired outcome, then the Room should be deconstructed into its child objects before using this component.
* **trans\_sch \[Required]**
A Honeybee ScheduleRuleset or ScheduleFixedInterval to be applied to the input \_hb\_objs. This can also be text for a schedule to be looked up in the shade schedule library. If an array of text or schedule objects are input here, different schedules will be assigned based on cardinal direction, starting with north and moving clockwise.
* **hb\_objs**
The input honeybee objects with their shade transmittance schedules edited.
