Face Result by Type
Separate data collections of energy simulation results by object and face type. Input data must be for Faces, Apertures, Doors, or any combination of these objects.
This component can also be used to normalize such data by area.
  • data [Required]
    A list of data collections output from an energy simulation, which will be separated by object and face type. Data collections can be of any class (eg. MonthlyCollection, DailyCollection) but they should all have headers with metadata dictionaries with 'Surface' keys. These keys will be used to match the data in the collections to the input faces.
  • hb_objs [Required]
    An array of honeybee Rooms, Faces, Apertures or Doors, which will be matched with the _data. This can also be an entire Model.
  • norm
    Boolean to note whether results should be normalized by the face/sub-face area if the data type of the data_colections supports it. (Default: False)
  • walls
    Data collections with results for Walls with an Outdoors or Ground boundary condition.
  • interior_walls
    Data collections with results for Walls with a Surface or Adiabatic boundary condition.
  • roofs
    Data collections with results for RoofCeilings with an Outdoors or Ground boundary condition.
  • ceilings
    Data collections with results for RoofCeilings with a Surface or Adiabatic boundary condition.
  • exterior_floors
    Data collections with results for Floors with an Outdoors or Ground boundary condition.
  • interior_floors
    Data collections with results for Floors with a Surface or Adiabatic boundary condition.
  • apertures
    Data collections with results for Apertures with an Outdoors boundary condition.
  • interior_apertures
    Data collections with results for Apertures with a Surface boundary condition.
  • doors
    Data collections with results for Doors with an Outdoors boundary condition.
  • interior_doors
    Data collections with results for Doors with a Surface boundary condition.
