Apply ConstructionSet
Apply ConstructionSet to Honeybee Rooms or a Model.
  • rooms [Required]
Honeybee Rooms to which the input _constr_set should be assigned. This can also be a Honeybee Model for which all Rooms will be assigned the ConstructionSet.
  • constr_set [Required]
A Honeybee ConstructionSet to be applied to the input _room. This can also be text for a construction set to be looked up in the construction set library.
  • rooms
The input Rooms with their construction sets edited.
