> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-energy-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-energy-primer/components/5_simulate/simulation_output.md). Agents can also search and read this documentation through its [MCP server](https://docs.ladybug.tools/hb-energy-primer/~gitbook/mcp).
# Simulation Output
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-aa1d8d29a2e1210de04f469169289e196072f163%2FSimulation_Output.png?alt=media)
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-6d31cd0814f6d984c1f87dc73fc2832631d7cfb0%2FSimulation_Output.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-energy/blob/master/honeybee_grasshopper_energy/src//HB%20Simulation%20Output.py)
Create a simulation output object by selecting sets of commonly-requested output variables. The resulting object can be used to request output variables from EnergyPlus.
* **zone\_energy\_use**
Set to True to add outputs for zone energy use when ideal air systems are assigned. This includes, ideal air heating + cooling, lighting, electric + gas equipment, and fan electric energy.
* **system\_energy\_use**
Set to True to add outputs for HVAC energy use from detailed systems. This includes outputs for different pieces of HVAC equipment, which together catch all energy-consuming parts of a system. (eg. chillers, boilers, coils, humidifiers, fans, pumps). It also includes the energy use of components of Service Hot Water (SHW) systems as well as any electricity generated on site, such at that coming from photovoltaics.
* **gains\_and\_losses**
Set to True to Add outputs for zone gains and losses. This includes such as people gains, solar gains, infiltration losses/gains, and ventilation losses/gains.
* **comfort\_metrics**
Set to True to add outputs for zone thermal comfort analysis. This includes air temperature, mean radiant temperature, relative humidity, and unmet setpoint time.
* **surface\_temperature**
Set to True to add outputs for indoor and outdoor surface temperature.
* **surface\_energy\_flow**
Set to True to add outputs for energy flow across all surfaces.
* **load\_type**
An optional text value to set the type of load outputs requested. Default - 'All'. Choose from the following:
* All - all energy use including heat lost from the zone
* Total - the total load added to the zone (both sensible and latent)
* Sensible - the sensible load added to the zone
* Latent - the latent load added to the zone
* **report\_frequency**
Text for the frequency at which the outputs are reported. Default: 'Hourly'. Choose from the following:
* Annual
* Monthly
* Daily
* Hourly
* Timestep
Report!
* **sim\_output**
A SimulationOutput object that can be connected to the "HB Simulation Parameter" component in order to specify which types of outputs should be written from EnergyPlus.
