Read Face Result
Parse all of the common Room-level comfort-related results from an SQL result file that has been generated from an energy simulation.
  • sql [Required]
  • face_indoor_temp
    DataCollections for the indoor surface temperature of each surface (C).
  • face_outdoor_temp
    DataCollections for the outdoor surface temperature of each surface (C).
  • face_energy_flow
    DataCollections for the heat loss (negative) or heat gain (positive) through each building surfaces (kWh).
